LACP Between Two Cisco Switches?
Jan 28th, 2010
Hi all – I am after some input on a configuration I am looking at.
I have 2 x 3750Gs which are stacked, and 2 x 3130s (DELL Blade Switch) also stacked. Note they are separate stacks. I need to connect them, preferably using LACP (I think). So, I figure I can setup an Etherchannel in the usual manner. Is this the normal/standard/accepted way to do it? Or am I all wrong?
I'd like to connect a each switch to both others – if that makes sense – so 4 connections between the two stacks to cover single points of failure, all on the same etherchannel, both active.
Any input appreciated!
Thanks.
Aaron
Jon Marshall Thu, 01/28/2010 - 04:09
Thanks.
Aaron
Aaron
Etherchannel is a normal way to connect switches to each other if you want redundancy and throughput.
Note that normally a restriction on etherchannel is that you cannot have the same etherchannel bundle spread across different switches. This restriction is not applicable to the 3750 switches because they support cross stack etherchannel but i don't know about the Dell switches, so you need to check.
LACP is the way to go as PaGP is Cisco proprietary.
Jon
Related Content
