3 IP adreses and Cisco ASA 5505
Jan 28th, 2010
Hallo!
I am a realy newone @Cisco.
I own Cisco ASA 5505.
We have one UTP Ethernet cable (RJ45) witch handles three IP adreses. One adress is fot IP telephony, second one for computer network and third is reserved for our public WEBserver, but it is no active now and will not be active about one year.
What could be the best way to configure ASA?
Static NAT?
Ganesh Hariharan Thu, 01/28/2010 - 03:24
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hallo!
Static NAT?
Check out the below links on ASA 5505 for basic understanding of configuration and scenario based configuartion.Hope it helps out your query !!
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/int5505.html
http://www.cisco.com/en/US/docs/security/asa/asa72/getting_started/asa5505/quick/guide/dmz.html
Ganesh.H
matiss.jekabsons Thu, 01/28/2010 - 04:04
Thx for your reply.
For now i have configured one of the IPs with static NAT like
#static (inside,outside) a.b.c.d a.b.c.d netmask 255.255.255.255
And i was using exactly thouse manuals + Cisco Cookbook (O'Raylie)
For now i am trying to make a correct Dinamic NAT from 2nd public IP.
Ganesh Hariharan Thu, 01/28/2010 - 07:33
Thx for your reply.
Yes that command will static nat  on pix and check out the below link for beginers on pix natting configuration with different scenarios hope that claers out your query.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00800b6e1a.shtml#multi_global
If helpful do rate the valauble post
Ganesh.H
Related Content
