drissbenattou Thu, 01/28/2010 - 04:25
Go to http://www.cisco.com/cgi-bin/tablebuild.pl/CME-Locale
  • You must have an account on Cisco.com to access the Software Download Center.
  • Select your version of Cisco Unified CME.
  • Select the TAR file for the locale you want to install. Each TAR file contains locale files for a specific
language and country and uses the following naming convention: CME-locale-language_country-CMEversion
  • Download the TAR file to a TFTP server that is accessible to the Cisco Unified CME router. Each file
contains all the firmware required for all phone types supported by that version of Cisco Unified CME.
  • Use the archive tar command to extract the files to flash, slot 0, or an external TFTP server.
                 Router# archive tar /xtract source-url flash:/file-url
  • For example, to extract the contents of CME-locale-de_DE-4.0.2-2.0.tar from TFTP server 192.168.1.1
to router flash memory, use this command:
                  Router# archive tar /xtract tftp://192.168.1.1/cme-locale-de_DE-4.0.2-2.0.tar flash:
you have to add the following lines :
tftp-server flash:es-td-sccp.jar alias Spanish_Spain/td-sccp.jar
tftp-server flash:es-mk-sccp.jar alias Spanish_Spain/mk-sccp.jar
tftp-server flash:es-tc-sccp.jar alias Spanish_Spain/tc-sccp.jar
tftp-server flash:es-gp-sccp.jar alias Spanish_Spain/gp-sccp.jar
tftp-server flash:es-ipc-sccp.jar alias Spanish_Spain/ipc-sccp.jar
tftp-server flash:g3-tones.xml alias Spain/g3-tones.xml
Note : I don't know if the phone files are the same as what's mentionned in the top.
All of these files will be found in the Dowload Center
Driss
