LMS 3.1 integration with ACS 5.0
Jan 28th, 2010
Can i integrate LMS 3.1 with ACS 5.0??
While integrating, i found the below error message. ACS & LMS open via "HTTPS".
In ACS, LMS is added as AAA Client.
My LMS username is: admin
I am using the same username in "ACS Admin Name" while integrating.
Kindly suggest.
yjdabear Thu, 01/28/2010 - 17:49
LMS 3.1 (CS 3.2) supports integration with ACS up to v4.2:
You'll need to upgrade to LMS 3.2 (CS 3.3) to gain ACS 5.0 support, with a caveat it's "(only for authentication services)".
"This allows to you the authentication services. However, the authorization services should be used from the local CiscoWorks Server."
