Compatible JRE version for CADv7.0(1) & EIM/WIMv4.2(5)
Jan 28th, 2010
Hi all,
I've encountered an issue where CAD uses jre1.6.0_12 (automatically download if PC is having old version) while EIM/WIM uses jre1.6.0_07 (KB console hangs when using higher version but the rest of the features looks to be ok).
My question is
a) what is the minimum jre that CAD needs & is it working with the latest jre version (now 17/18)
b) is there a workaround (some jre parameter setting?) to use a higher version of jre for EIM/WIM
c) do you set jre to auto update?
Thanks!
-JT-
