PIX Xlate
Jan 28th, 2010
Currenltly we are using static NAT entry more than 400 entries can i know how much xlate entry can PIX support
is there will any issue with the CPU or memory
Free memory:        88561736 bytes (66%)
Used memory:        45655992 bytes (34%)
Total memory:      134217728 bytes (100%)
CPU load is 20 %
model : Hardware:   PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz
Flash 16MB
BIOS  32KB
is this normal ?
kindly advice
thanks in advance
vinu
vilaxmi Thu, 01/28/2010 - 08:14
  • Cisco Employee,
Depending on platform of PIX, there can be different upperbound limit for # of XLATE entries that the hardware can support.
For a PIX 515E 400 NAT entries should not be much of a problem and 20% memory usage is also quite normal at high usage I have seen memor rise upto 90 % and above. Normal memeory usage for your firewall  is around 70-80 %. And usually firewalls can support around 10s of 10000s of NAT/ACL entries. There may have been stress testing done for getting the exact number , but I guess there is no document to testify the figures (datasheets may help)..
Vijaya
