01-28-2010 07:59 AM - edited 03-06-2019 09:29 AM
Migrating from PVST to RapidPVST. Has anyone done this in an existing network? Will it cause STP to recalculate ie downtime?
01-28-2010 08:03 AM
Hi Mike
PVST and Rapid PVST are backward compatible..the bpdu version 2 is compatible with 802.1D STP..
you will not have any downtimes, but it is better to do it a with a scheduled change window (Just in case !)
have a look at this URL for more info on this migration:
Hope this helps.. all the best
Raj
01-28-2010 08:04 AM
Yes, it will cause an STP reconvergence and Cisco recommend migrating in a scheduled downtime. To be honest pretty much most things to do with STP should be done that way. There is a doc for migrating from PVST+ to Rapid-PVST, good idea to have a read -
Jon
01-28-2010 08:07 AM
Migration from PVST to RPVST will require a downtime as Rapid-PVST+ uses the same BPDU format as the 802.1D and it is backward compatible.Because of the backward compatibility, you can convert phase by phase. It is recommended to implement the changes in the scheduled maintenance window because the spanning tree reconfiguration disrupts the traffic flow.
Spanning Tree UplinkFast and BackboneFast features are PVST+ features. These are disabled when you enable rapid-PVST+ because those features are built within rapid-PVST+. Therefore, during the migration you can remove those commands. The configuration of the features such as PortFast, BPDUguard, BPDUfilter, root guard, and loopguard are applicable in rapid-PVST+ mode also The usage of these features are the same as in PVST+ mode. If you have already enabled these features in the PVST+ mode, the features remain active after the migration to rapid-PVST+ mode.
Hope to help
Ganesh.H
01-28-2010 01:04 PM
I did not think it will cause downtime as sadly most of our closets do not have redundant links. I suppose we revert to the saying "better safe than sorry".
Thanks for the input.
01-28-2010 10:45 PM
Mike,
Downtime means stp will re converge and in that case available ports can become blocking ports for the traffic and as per the recommendation from cisco if in switching environment you are playing with configuration of stp you should better to have downtime planned so that convergence time can be used in the down time to overcome the panic state.
Hope to help
Ganesh.H
01-29-2010 06:20 AM
The downtime should not be that long , we are talking a spanning tree recalc which is maybe 50 seconds at it longest and probably less than that . Do it off hours . Most networks have windows in which changes are allowed to be made.
