JORGE RODRIGUEZ Thu, 01/28/2010 - 13:48
  • Green, 3000 points or more
Fuller,   annyconnect does not work with any  PIX as far as I know,   your solution to using Annyconnect client in Windows 7 64 bit is to upgrade your PIX506 with at least ASA5505 which is its upgrade path, then you can think of Annyconnect client implemenation  for 64 bit platforms.
Here is ASA specs  if you upgrade
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
Lastly you can also reference this link posted  by Nelson on Q&A of Annyconnect
https://supportforums.cisco.com/docs/DOC-1361
pudawat Thu, 01/28/2010 - 16:43
HI,
If replacing the PIX is not you option go for L2TP over IPSEC or PPTP.
Even the Windows 7(64 bit) native VPN client would work with it.
the link to setit up L2TP over IPSec is as follows:
www.cisco.com/en/US/products/ps6120/products_configuration_example09186a...
the link to setup PPTP is:
www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_ex...
Pradhuman
clark.d Thu, 01/28/2010 - 19:02
shrew.net......open source vpn client that suppots Windows 7 x64 AND pcf file import........
