01-28-2010 01:22 PM - edited 03-09-2019 10:48 PM
Hi All,
Is Object Groups based ACLs supported on C3750G switches? I could not find anything on the Cisco web site about this.
Solved! Go to Solution.
01-29-2010 03:34 AM
Hi All,
check out the below link on object group ACL it is supported with 12.4(20)T realease but i dont think it is supported with cisco 3750G series switch what i can see from navigator in cisco.Hope thae help !!
If helpful do rate the valauble post
Ganesh.H
01-29-2010 03:34 AM
Hi All,
Ganesh.H
