Re: Cisco Unified Communication Manager 7.1.3 Softkey Template
Jan 28th, 2010
I would like to have the modify the softkey template to allow a call to be transferred when the dialed number rings, the options which are available are ring
How do I change this?
Jaime Valencia Thu, 01/28/2010 - 14:03
  • Cisco Employee,
  • Hall of Fame,
    2011
You cannot transfer a call unless you answer it, the only option would be to use idivert which send the call to VM.
If you want to transfer while ringing to anything else but VM that's not possible, that's why the transfer softkey is not available on that call state.
m-laing Thu, 01/28/2010 - 14:38
This feature is was available with Call Manager release 4.1 and also 6.0, is there a reason for this change?
