SFP security failure after IOS upgradation
Dear Team,
                 I have upgraded my Cisco 7206 VXR NPE G1 box from "slot2:c7200-p-mz.122-18.S6.bin" to "c7200-advipservicesk9-mz.124-22.T4.bin".The box is having cuople of POS ports with SFP ( SFP-OC3-IR1=). After the upgradation the port is down and showing "SFP security Failure".and if iam rolling back to old IOS it is working fine.
Do any body assist me why this is happening???Do any new IOS Train which wont post this ???
Thanks in Advance for any assistance.
Mahesh Vjayan.
Module details
Dual OC3 POS Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time 21:14:17 ago
EEPROM contents at hardware discovery:
Hardware Revision        : 1.0
PCB Serial Number        : JAE0845ZK51
Part Number              : 73-8220-03
Board Revision           : A0
RMA Test History         : 00
RMA Number               : 0-0-0-0
RMA History              : 00
Deviation Number         : 0
Product Number           : PA-POS-2OC3
Top Assy. Part Number    : 800-21857-03
EEPROM format version 4
EEPROM contents (hex):
Giuseppe Larosa Tue, 02/02/2010 - 05:55
  • Hall of Fame,
    Founding Member
Hello Mahesh,
I couldn't find an exact match bug for your problem but only one somewhat related:
CSCta80298 Bug Details Bug #1 of 3 | < Previous            | CSCtd74820&from=summary">Next >
Cisco 7200-SFP Port Container shows POS port wrongly in Entitymib
Symptom:Cisco 7200-SFP Port Container shows POS port wrongly in Entitymib
Conditions:Cisco 7200-SFP Port Container shows POS port wrongly in Entitymi
to be noted this was found in 12.4(24)T1.
I would suggest you to try with a 12.4(20)T image same feature set unless there is a specific feature you need present only on 12.4(22)T
Hope to help
Giuseppe
