LMS 3.2 - restorebackup.pl issues with /var permissions on Solaris 10
Jan 28th, 2010
I have been attempting a restore using the restorebackup.pl script but it was repeatedly failing 70% of the way through the RME restore.
I discovered that the script was changing the directory permissions for /var and /var/adm from root:sys 755 to root:root 700 causing the restart of daemons to fail because of denied permissions.
What could be causing this change in permissions to /var and /var/adm to occur? Is it an error with the script?
I was able to successfully restore using the restorebackup.pl script after changing the /var and /var/adm permissions back to root:sys 755 BUT only after the restorebackup script had changed them to root:root 700 during execution.
The failed log is attached.
Joe Clarke Sat, 01/30/2010 - 10:14
There is no where in the restore code where anything is explicitly chmod'd to 0700.  In fact, the RME restore code will attempt to preserve ownership of /var and /var/adm.  Perhaps the permissions in your RME filebackup.tar file are already 0700 for /var and /var/adm?
Related Content
