Which auto update URL is the correct one?
Jan 29th, 2010
I use the default one (https://198.133.219.25/cgi-bin/front.x/ida/locator/locator.pl) on my 7.x IPS system and keep getting  "http error response: 400" for some time now. Should I use a different URL or may I have overlooked another problem?
Fredrik
mattwi Fri, 02/12/2010 - 16:14
You may be running into a resource contention with cisco.com. All the sensors in the world try to connect at the same time, try changing the time to check for updates to some number of minutes after the top of the hour.
