Redistribution problem (2 networks)
Answered Question
Jan 29th, 2010
Dear sirs
I have one problem which I can not think a way how to solve it. As you can see from the diagram I have 2 networks . One of the network is running RIP version 1 and the other EIGRP. I want to connect the Switch A to Switch B so both networks can communicate.
Until today I connected Router A to Switch B and I configured redistribution between those 2 protocols on both devices and it was working fine. Now I want to include also Switch A in the network . My problem is that if I connect Switch A to Switch B , Switch A is Layer 2 and I can not configure redistribution on it. Of course Switch B is 4500 series and it’s running Full EIGRP on it.
If I connect the 2 switches what shall i do so all the routes from both networks can be exchanged ?
Thanks a lot
Moses
29 Jan 2010
Correct Answer by Jon Marshall about 7 years 1 month ago
moses12315 wrote:
Yes Jon, i am sorry it was quite confused. What i meant is that i connected at the past (3 days)
ago the L3 Switch (Switch B) with the Router 1 and after i did redistribution it worked.(Router 1---> Switch B---> Router 2).
The problem is that i want to connect Switch A in the network (Router 1 --> Switch A ---> Switch B---> Router B).(Don't forget Switch A is a 2950 Switch L2)
As i understood you told me to do this connection and the routes from Rip and Eigrp will be exchanged. Am i right?
I will try it on Monday and i will informed you .
Thanks a lot anyway
Moses
Moses
No problem.
Yes it will work fine as long as you use the same vlan on both ports on Switch A your routing and redistribution will not be affected.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Fri, 01/29/2010 - 02:03
moses12315 wrote:
Dear sirs
Thanks a lot
Moses
29 Jan 2010
Moses
It's not clear what you mean by -
Is router A the one running RIP ?
If so then you can simply add the L2 switch in between and this will not affect any L3 route redistribution. Simply connect Switch B to a port on Switch A and connect router A to another port on Switch A and make sure the ports are in the same vlan and it will all work.
If router A is not the one running RIP could you clarify.
Jon
moses12315 Fri, 01/29/2010 - 10:56
Thanks a lot anyway
Moses
Correct Answer
Jon Marshall Fri, 01/29/2010 - 11:01
Thanks a lot anyway
Moses
Moses
No problem.
Jon
moses12315 Mon, 02/01/2010 - 07:56
Dear Jon,
You were right one more time. I did as you told me and it works fine.
Thanks a lot for your help. Even though i do not understand the theory behind all this , at long as it works i am happy.
Thanks again for your help .
Moses
