Encryption Evidence
Jan 29th, 2010
Hi Srini,
How we can show an evidence saying my data is getting ecrypted over the VPN network.
I am running an IP-SEC VPN and i want to show an evidence saying the packets are getting encrypted.
One option was to show the counters count Inbound / outbound, but which was not that much supportive.
Is there any option to show some evidence of ecnryption???
Gopi
Overall Rating: 5 (1 ratings)
Collin Clark Fri, 01/29/2010 - 07:41
  • Purple, 4500 points or more
Try the following command-
show crypto ipsec sa
interface: Tunnel0
    Crypto map tag: vpn, local addr 69.222.73.2
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (69.222.73.2/255.255.255.255/47/0)
   remote ident (addr/mask/prot/port): (69.222.73.1/255.255.255.255/47/0)
   current_peer 69.222.73.1 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 52438988, #pkts encrypt: 52438988, #pkts digest: 52438988
    #pkts decaps: 1013823840, #pkts decrypt: 1013823840, #pkts verify: 1013823840
This is showing the number of packets this router is encrypting and decrypting with its peer.
Hope that helps.
james.bastnagel Sat, 01/30/2010 - 21:52
If that doesnt work--provide enough evidence, then run a sniffer on the
outside interface of one of your vpn devices and you can show that the
payload of the packets is in fact encrypted.
On Fri, Jan 29, 2010 at 5:01 PM, pudawat
