No discover file for CWLMS?
paulhowlett_2
Hi, is it possible to to prevent CWLMS from polling certain IP addresses on devices that are in the inventory? For example only poll the management interface but not specific VLAN interfaces?
Thank you in advance.
Joe Clarke
DFM is really the only application that does this.  DFM will attempt to ping each IP address on the device to determine if that address is reachable.  You can unmanage IP addresses that you do not wish to ping under DFM > Device Management > Device Details.  As for polling interface states, DFM will do this as will Campus Manager.  However, the SNMP queries will all go through the primary management IP of the device.
Joe Clarke
Great, thank you for your help.
