CISCO AIR-LAP1252AG-A-K9 Autonomous DHCP config?
Jan 29th, 2010
N00b questions:
  1. Can the 1252AG provide server DHCP in the Autonomous IOS configuration ? ( The WAP is connected to a Linksys router that is providing a NAT address via DHCP to the ethernet interface)
  2. What is the most basic DHCP configuration option ?
  3. I'm assuming the WAP can also pass through the NAT / DHCP from the Linksys router ? What would be the most basic configuration for that?
nickml007 Fri, 01/29/2010 - 08:48
"Configuring the Access Point to Provide DHCP Service
These sections describe how to configure the access point to act as a DHCP server:
•Setting up the DHCP Server
•Monitoring and Maintaining the DHCP Server Access Point
By default, access points are configured to receive IP settings from a DHCP server on your network. You can also configure an access point to act as a DHCP server to assign IP settings to devices on both your wired and wireless LANs."
I'm assuming this also applies to the 1252?
Related Content
