editing with CUE Script Editor
Jan 29th, 2010
I am editing the script on our Auto Attendant (CUE 2.3).  I've had problems with the edited script, so I tried breaking down the steps and started with simply downloading the existing, functioning script, renaming it, uploading it, and then setting the AutoAttendant to use the copy.
I get an error that says "Application created successfully, but might not be fully functional due to internal errors."
And it isn't- the Autoattendant stops working when you call in, but works again when set to the old script.
What could be causing the problem?
Thanks, Amanda
Amanda Byrne
IT Administrator
Carolina Tiger Rescue
markbatts Mon, 02/01/2010 - 09:18
I've not had exactly that problem but i have seen issues with uploading scripts to unity express especially on the older versions 2.x .
I would suggest you restart the unity express module , tends to cure alot of "weird" problems :-)
cheers
Mark
Related Content
