ASA 5505
Jan 29th, 2010
We are ordering a ASA 5505 for a small remote office of 10 users and I will set up a VPn to our HQ.  I have never used this lower model before (only the 5510/5520) so I wondered do I just assign one of the 8 ports as the 'outside' and put it in the VLAN where the lease line router is and one as the 'inside' and connect to the office vlan switch?  The just do the usual settings of IP address and security levels.
I assume it just the same as sessing up a 5510/5520?
Collin Clark Fri, 01/29/2010 - 08:51
  • Purple, 4500 points or more
All of your assumptions are correct and you're also right about assigning a physical port to the 'outside' vlan.
