1600 Series Router & WIC-1ADSL
Answered Question
Jan 29th, 2010
I have some 1600 series routers and was hoping to use them for my Broadband connection.
Is this WIC compatable with the 1600 series router?
What is the required IoS if this is posible?
Thanks Ian
Correct Answer by Ganesh Hariharan about 7 years 5 months ago
Ganesh,
Thank you for the response, however, that article is for the WIC-1DSU-T1 as far as I can see.
I was wanting information regarding the WIC-1ADSL. which does not appear to be recognised in my 1603R routers.
Thanks Ian
Ian,
The ADSL WAN interface cards (WICs) supported on the Cisco 1700/2600/3700 series routers are also supported on the Cisco 1800 (modular), 2800, 3800 series Integrated Services Routers (ISRs).
As per the link it start supported only from 1700 series routers ony.
Check out the below link hope that clears out your query !!
http://www.cisco.com/en/US/prod/collateral/routers/ps221/product_data_sheet0900aecd8028aa5a.html
If helpful do rate the valauble post
Ganesh.H
Overall Rating: 5 (1 ratings)
Ganesh Hariharan Fri, 01/29/2010 - 22:32
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Thanks Ian
Ian,
Check out the below link for your queries hope to help !!
http://www.cisco.com/en/US/products/hw/modules/ps3129/products_tech_note09186a0080093d70.shtml
Ganesh.H
g6khw Sat, 01/30/2010 - 04:08
Ganesh,
Thanks Ian
Correct Answer
Ganesh Hariharan Sat, 01/30/2010 - 04:47
Ganesh,
Thanks Ian
Ian,
Ganesh.H
g6khw Sat, 01/30/2010 - 07:24
Looks like I will have to get a newer router to do the job.
Good idea whilst it lasted!
Ian
