rtjensen4 Fri, 01/29/2010 - 13:00
  • Bronze, 100 points or more
Depending on the switch you are using, you can use the quick and dirty srr-queue bandwidth limit command.
Limits bandwidth to a percentage of port speed. ONLY works on outbound traffic.
Example:
interface fa0/1
speed 100
srr-queue bandwidth limit 10
This example would yield a 10mbps rate-limit.
or
interface fa0/1
speed 10
srr-queue bandwidth limit 30
This example would yieled a 3mbps rate-limit.
Keep in mind this only works on traffic outbound from the port.
yuhuiyao Fri, 01/29/2010 - 13:04
Thanks for your reply.
Can I use rate-limit input/output command?
Can I use service-policy input/output command?
rtjensen4 Fri, 01/29/2010 - 13:23
Depends what kind of switch you are using. I know on my 4500s, I can do somthing like this:
policy-map ratelimit-policy
class limitclass
    police 772 kbps 56 kbyte conform-action transmit exceed-action drop
interface GigabitEthernet4/47
switchport access vlan 503
bandwidth 30000
load-interval 60
speed 100
duplex full
spanning-tree portfast
spanning-tree bpduguard enable
service-policy output ratelimit-policy
end
All depends on the capabilities of the switch. What kind are you using?
