881 remote VPN client
Jan 29th, 2010
Does the 881 support any type of client ipsec remote VPN access.  Such as connecting to the router via the Cisco VPN client software on a laptop.  I understand SSL is an option but i am wondering if ipsec is possible.
pudawat Fri, 01/29/2010 - 16:35
Hi Eric/Nisha,
Cisco IPsec VPN clients can connect to Cisco IOS Router 881.IT IS SUPPORTED!!!
Just follow the link to configure it:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_configuration_example09186a0080819289.shtml
Easy VPN is a different technology which is basically a Hardware client(ASA,Router) getting connected to The VPN server (ASA,Router)
I think Eric wants to use software VPN client.
Pradhuman
jperalta1 Mon, 10/14/2013 - 15:56
Favor confirmar si existe algun numero maximo de conexiones VPN client-to-site que puede soportar el Router Cisco 881 de clientes que usen el Software Cisco VpnClient
Related Content
