Unity 4.02
I im in the process of  migrating Unity 4.0.2 onto a new server.. The problem I had was I used windows to load on the new server as I didnt have the product configuration disks for windows 2000 on a mcs 7825 i3. So I loaded windows form cd. I was okay all was fine untill I did the dirt restore now AVCSMGR will not start, It complains about MIU and it cannot find te license file,,,
The only thig that I see is the old machine windows is installed on "c:\windows" and mine is "c:\winnt"  I suspect this is the issue as all was okay before dirt..
Any ideas on how to fix this
problem
mightyking Fri, 01/29/2010 - 18:43
Any errors in the application log?
Remember your Unity License is tied into the MAC address of the NIC card.  If you change the server, you need to have TAC to update your license file with the correct MAC address. Has it been done?
MK
