Possible to span 1 port to multiple destination ports?
Jan 29th, 2010
I have a Catalyst 2950 switch. I was wondering if it's possible to span one source port to multiple destination ports or a destination VLAN? I've read that it can be done and I've read that it can't be done.
If it can't with the switch does anyone know anything better than a hub to use?
Reason I ask is I have a IDS setup on a couple different platforms and wanted to test to make sure they all were able to catch the same thing on each one.
sachinraja Fri, 01/29/2010 - 18:11
  • Red, 2250 points or more
I think it really depends on the hardware and software OS version...
The 2950 i think just supports one detination port on SPAN...The following URL confirms this:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_11_yj4/configuration/guide/swspan.html#wp1036816
From the document it clearly says - "You can have only one destination port. "
whereas layer 2 swtiches like 2960 with 12.2 (40)SE IOS, can support multiple destinations... refer the following URL;
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_40_se/configuration/guide/swspan.html
on the command set you can see:
monitor session session_number destination {interface interface-id [, | -] [encapsulation {dot1q | replicate}]}
Note You can use monitor session session_number destination command multiple times to configure multiple destination ports.
Hope this helps.. all the best..
Raj
Ganesh Hariharan Fri, 01/29/2010 - 22:02
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
As per the span guidelines by cisco for cat 2950 switches you can have only one destination port.
Hope to help
Ganesh.H
