Ether Channel config
Answered Question
I have just set up Ether Channel on a 295
0 with 12.1 IOS, but when I go to the other switch (2950 12.0 IOS) I get an erro
r when I try to create the Channel group. I have included available commands to sh
ow they are valid. Any ideas?
SB>en
SB#config t
Enter configuration commands, one per line.  End with CNTL/Z.
SB(config)#int Port-channel ?
  <0-2147483647>  Port-channel interface number
SB(config)#int Port-channel 1
% Invalid input detected at '^' marker.
SB(config)#
Correct Answer by glen.grant about 7 years 3 months ago
  Steve just enter this on both and it should come up.  Substitute whatever ports you are using in the interface range command. It's important to bring both ports up at the same time when creating etherchannels.
int range f0/1 - 2
channel-group 2 mode desirable non-silent
no shut
Correct Answer by Ganesh Hariharan about 7 years 3 months ago
SB>en
SB#config t
SB(config)#
Steve,
When you create an EtherChannel for Layer 2 interfaces, a logical interface is dynamically created. You then manually assign an interface to the EtherChannel by using the channel-group interface configuration command which creates the port-channel logical interface.
You configure Layer 2 EtherChannels by configuring the Ethernet interfaces with the channel-group interface configuration command, which creates the port-channel logical interface.
and Reza has rightly pointed for channel-group-number, the range is 1 to 6
To conifgure a etherchannel follow the following steps:-
Step 1
configure terminal
Enter global configuration mode.
Step 2
interface interface-id
Enter interface configuration mode, and specify a physical interface to configure.
Valid interfaces include physical interfaces.
Up to eight interfaces of the same type and speed can be configured for the same group.
Step 3
channel-group channel-group-number mode {auto [non-silent] | desirable [non-silent] | on}
Assign the interface to a channel group, and specify the PAgP mode. The default mode is auto silent.
For channel-group-number, the range is 1 to 6. Each EtherChannel can have up to eight compatibly configured Ethernet interfaces.
Step 4
end
Return to privileged EXEC mode.
Step 5
show running-config
Verify your entries.
Hope that clear out your query
If helpful do rate the post
Ganesh.H
Correct Answer by Reza Sharifi about 7 years 3 months ago
Hi Steve,
In config mode when you do a interface ? do you see Port-channel as an option?
Here is on out put from a 2950.
I also wonder why that number is do large when you issue command "int port-channel and ?
I can create etherchannel with no problems and the maximum is 6
Management-Switch(config)#interface ?
  Async              Async interface
  BVI                Bridge-Group Virtual Interface
  Dialer             Dialer interface
  FastEthernet       FastEthernet IEEE 802.3
  GigabitEthernet    GigabitEthernet IEEE 802.3z
  Group-Async        Async Group interface
  Lex                Lex interface
  Loopback           Loopback interface
  Multilink          Multilink-group interface
  Null               Null interface
  Port-channel       Ethernet Channel of interfaces
  Tunnel             Tunnel interface
  Virtual-Template   Virtual Template interface
  Virtual-TokenRing  Virtual TokenRing
  Vlan               Catalyst Vlans
  range              interface range command
Management-Switch(config)#interface po
Management-Switch(config)#interface port-channel ?
  <1-6>  Port-channel interface number
Management-Switch(config)#interface port-channel 2
Management-Switch(config-if)#
Reza
Overall Rating: 5 (3 ratings)
Correct Answer
Reza Sharifi Fri, 01/29/2010 - 21:27
  • Cisco Designated VIP,
    2017 LAN
Hi Steve,
  Lex                Lex interface
  Null               Null interface
  Vlan               Catalyst Vlans
Reza
I cheated a litte and upgraded the IOS on the switch to match the other 2950 (12.1) and it worked just fine. I build the Port channel with the int command, then assign the ports, and I now have the bundle working. Yes, on the 12.0 IOS I could not create the Channel Group with the int port-channel xx but the comand was listed in the help feature.
Would it make sense that the setup is different from 12.0 to 12.1 ?? Here is the config that worked. (12.1)
SA#en
SA#config t
SA(config)#int port-channel 5
SA(config-if)#int range f0/11 - 12
SA(config-if-range)#switchport mode trunk
SA(config-if-range)#channel-group 5 mode on
SA(config-if-range)#switchport nonegotiate
Reza Sharifi Sat, 01/30/2010 - 12:14
    2017 LAN
Glad it worked.  My 2950 also is running 121 and it works both ways
c2950-i6q4l2-mz.121-19.EA1c.bin
I can create the Etherchannel first and then add the ports to it or just go to the physical port and add it to a new channel-group number.
Reza
Correct Answer
Ganesh Hariharan Fri, 01/29/2010 - 21:57
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
SB>en
SB#config t
SB(config)#
Steve,
Step 1
configure terminal
Step 2
Step 3
Step 4
end
Step 5
show running-config
Ganesh.H
Correct Answer
glen.grant Sat, 01/30/2010 - 03:37
int range f0/1 - 2
no shut
I have added another port and connection to the Port channel, and it has crashed. I know if I wiped the config and rebuilt it, I would get it working, but I really want to learn how to see what's wrong/troubleshoot the issue. I plugged in another cable into port 4, no issues, when I ran the same commands on that port to make it a trunk and to add it to the group, it crashed. At frist I thought this was only because I had yet to configure the other switch on the other end of the bundle, but now that the other side is also completed, the port channel will not come back (link light out, errdisable state). I have looked at too many things to post here, so I will start by asking which show command is best to start with?
I have verified the correct ports are in the correct group:
SA#sh etherchannel summary
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        u - unsuitable for bundling
        U - in use      f - failed to allocate aggregator
        d - default port
Number of channel-groups in use: 2
Number of aggregators:           2
Group  Port-channel  Protocol    Ports
1      Po1(SD)          -
4      Po4(SD)          -        Fa0/4(D)    Fa0/5(D)    Fa0/6(D)
                                 Fa0/7(D)    Fa0/8(D)
ALSO, Running config shows the proper config:
interface FastEthernet0/1
interface FastEthernet0/2
switchport access vlan 2
switchport mode access
interface FastEthernet0/3
switchport access vlan 3
interface FastEthernet0/4
channel-group 1 mode on
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
Reza Sharifi Sat, 01/30/2010 - 16:00
    2017 LAN
2950 is a layer-2 device only.  You can only have one SVI interface at a time and the only purpose of the one SVI interface is for management.  That is why when you create another SVI interface it bring down the first one.  If you want to have the ability to create multiple SVIs and do routing then you need another switch like a 3560 and/or 3750.
Take a look at this section of this document:
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_configuration_example09186a008009478e.shtml#confthevlancat
Reza
