i have a cisco 877
Jan 30th, 2010
hi
i have a cisco 877..........i got some commands to set a VPN client..but i dont know where i have to enter the commands .............if its TCP IP
...tell me how to take that   mostly all the commands are like router#(config) i tryied in hyper termnal no command i got like that wher i have to enter this
what is the use of a console wire ?....i have console wire what is the use of that?.........i have ssm software when i installed and its asking SSH password
what is that .............?........when i am given the port ip is current ip of the system .......please help me
pudawat Sun, 01/31/2010 - 09:21
HI Tony,
Just do "router#sh ver" command to see whether a crypto K9 image is installed on the router.
If you have issues with the command line try to do configuration via GUI i.e SDM for Router.
Prdahuman
tonykg2000 Sun, 01/31/2010 - 23:10
hi
its saying that ios software c870
i have one more doubt when u trying to config the interface
am typing interface fastethernet0
then its getting the message like
(config-if) its should come like config-int right
my cisco 877
On Sun, Jan 31, 2010 at 10:51 PM, pudawat <
