CAC/AAR, ISDN Ringback and Disconnect delay
Jan 30th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
I have two questions, but both are somewhat related.
I have call admission control and AAR configured on a 9 sites with a central Call Manager 7 cluster.
One site which has only a 128k link into it has 3 ISDN lines (6 channels).  All inbound calls hit an Unity Auto Attendant through the WAN so with 6 ISDN channels there’s potential of easily  over subscribing the 128K WAN.
On testing this, I’ve come to realise that the CAC/AAR is not functioning correctly, but only where the CTI route point in concerned.  When the calls come in, they’re directed to a CTI Route Point which puts the call into Unity.  I have the CTI RP set up the same way as any extension on that site.  As a test, if I lower the bandwidth allocation of the remote site to something that wont’ even allow one call and I attempt to call another phone across the WAN, CAC/AAR kicks in and the call is rerouted out through the PSTN. However if I try to call the CTI Route point extn#, the CAC kicks in but it doesn’t reroute the call, so the call is prevented from connecting across the WAN but not rerouted out to the PSTN.
When I call into the site externally, where the incoming call is translated to the CTI Route Point, the caller hears ringback.  This doesn’t make sense as if the call got through the route point, the AutoAttendant would answer.
So basically, AAR isn’t working for my CTI Route Point, and callers are hearing ringback even though CAC has prevented the call from connecting to the route point.
I have read something about route point and AAR and I will keep digging but I don’t even know what to look for regarding the ringback when nothing is actually ringing.
Thanks in advance,
Neil
DEBUGS:
CAMP-THUR-RTR01#
040313: Jan 30 13:40:27: ISDN BR0/0/0 Q931: RX <- SETUP pd = 8  callref = 0x2D
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x2183, 'XXXXXXXXX'
                Plan:ISDN, Type:National
        Called Party Number i = 0x81, '1444'
                Plan:ISDN, Type:Unknown
040314: Jan 30 13:40:27: ISDN BR0/0/0 Q931: TX -> CALL_PROC pd = 8  callref = 0xAD
        Channel ID i = 0x89
                Exclusive, B1
CAMP-THUR-RTR01#
040315: Jan 30 13:40:27: ISDN BR0/0/0 Q931: TX -> DISCONNECT pd = 8  callref = 0xAD
        Cause i = 0x80A2 - No circuit/channel available
040316: Jan 30 13:40:28: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8  callref = 0x2D  THIS IS WHERE I SHOULD BE DISCONNECTED
040317: Jan 30 13:40:28: ISDN BR0/0/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0xAD
CAMP-THUR-RTR01#
040318: Jan 30 13:40:37: ISDN BR0/0/0 Q931: RX <- RELEASE pd = 8  callref = 0x2D  THIS IS WHERE I ACTUALLY HUNG UP
        Cause i = 0x8090 - Normal call clearing
CAMP-THUR-RTR01#
040319: Jan 30 13:40:39: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0/0/0, TEI 115 changed to down
CAMP-THUR-RTR01#
040320: Jan 30 13:40:39: ISDN BR0/0/0 Q931: Ux_DLRelInd: DL_REL_IND received from L2
