01-30-2010 10:05 AM
Hello friends,
i have discovered switches and routers through CDP,how can i discover ASA while CDP does'nt work on ASA,
Solved! Go to Solution.
01-31-2010 09:56 PM
You need to make sure you have SNMP properly configured on the ASA, and that those same SNMP credentials are configured in Discovery. If a device shows up as being unreachable, then that means Discovery could not communicate with it via SNMP.
01-30-2010 11:38 AM
You will need to use one of the non-CDP Discovery modules for this. Many customers choose Ping Sweep. This will work for the ASA provided you allow ICMP.
01-30-2010 12:00 PM
Thanks,i will try i will come back to u
01-31-2010 10:49 AM
hello clarke,
I have enabled ping seep module for discovery but i could'nt found ASA it is unreacheable and found by systems,
thanks,
01-31-2010 09:56 PM
02-02-2010 10:58 PM
Also note that an ASA will always show up as an unconnected device in Campus Manager since it does not have CDP adjacency with any other device.
