AP 1131 Multiple SSID VLANS
Jan 30th, 2010
Hi, I have problem with AP 1131, my company needs to create 2 vlans one for admin and the other for visitor each one should be in vlan i have configured the router and switch for this and if the connection through wired cables it works great( it give for each IP from differnet range) now i want the wireless clients to work with this configuration and to have multiple ssid i can c the 2 ssids (admin and visitor) when ever i try to connect to one of them it does not associate to any one.
it is autonoums AP i have no controllers and this will apply to 4 AP
the configuration is:
version 12.3
no service pad
service password-encryption
hostname ap
ip subnet-zero
no aaa new-model
dot11 vlan-name Admin vlan 20
dot11 vlan-name visitor vlan 30
dot11 ssid Admin
   vlan 20
   max-associations 50
   mbssid guest-mode
dot11 ssid Visitor
   vlan 30
   max-associations 50
   mbssid guest-mode
dot11 network-map
power inline negotiation prestandard source
username Cisco password 7 14341B180F0B
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid Admin
ssid Visitor
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
bridge-group 20 spanning-disabled
interface Dot11Radio0.30
encapsulation dot1Q 30
no ip route-cache
bridge-group 30
bridge-group 30 subscriber-loop-control
bridge-group 30 block-unknown-source
no bridge-group 30 source-learning
no bridge-group 30 unicast-flooding
bridge-group 30 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid Admin
ssid Visitor
mbssid
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface Dot11Radio1.20
no ip route-cache
bridge-group 20
interface Dot11Radio1.30
no ip route-cache
bridge-group 30
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface FastEthernet0.20
no ip route-cache
bridge-group 20
interface FastEthernet0.30
no ip route-cache
bridge-group 30
interface BVI1
ip address 10.1.1.1 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
thanks for your help
visahni Mon, 02/01/2010 - 21:54
Hi alkabeer,
Configure the following:
config)#dot11 ssid Admin
config-ssid)#authentication open
config)#dot11 ssid Visitor
