Troubleshooting cause code 47
Jan 29th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
at the moment the gateway has not yet been deployed and is not in active use. sh call history voice brief output on gateway is shown below
Telephony call-legs: 0
SIP call-legs: 0
H323 call-legs: 10
Call agent controlled call-legs: 0
Media call-legs: 0
Total call-legs: 10
1DB6 : 409 433052630ms.409 +-1 +11810 pid:20 Answer 235
dur 00:00:00 tx:0/0 rx:0/0 2F  (no resource (47))
IP 0.0.0.0:0 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g729r8 pre-iet
f TextRelay: off
media inactive detected:n media contrl rcvd:n/a timestamp:n/a
long duration call detected:n long dur callduration :n/a timestamp:n/a
Any solution on how to resolve this issue, will be most welcome.
yvonneobiero Sat, 01/30/2010 - 11:10
There are a couple of dial-peers being used apart from that one.. so after putting in voice service voip commands on gateway, the new error that i get is Cause code 47 is No Resources Available.....and the dial peer does get matched
Jan 30 08:55:32.910: //426/80ED719CE300/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4777AD20, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=235,(Calling Name=)(TON=Unknown, NPI=Unknown, Scre
ening=User, Passed, Presentation=Allowed),
   Called Number=118118883237117(TON=Unknown, NPI=Unknown), Calling Translated=F
ALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=21
, Call Count On=FALSE,
yvonneobiero Sat, 01/30/2010 - 12:27
Hi Bevilacqua,
will do that on monday and post the output.
have a gud weekend
Related Content
