Billing in ISR router 2821
Jan 30th, 2010
Is it actually possible to do the billing on an ISR router without using CME, like terminating the VOIP traffic on 2821 router and then sending it to Voice PRI. I will only need billing there wont be any CME. Please also suggest any billing software.
paolo bevilacqua Sun, 01/31/2010 - 11:37
  • Hall of Fame,
    Founding Member
Cisco doesn't make billing software, and by the way CME does not come with billin.
You have to choose among the many solutions available on the market.
zohaib.shabir Sun, 01/31/2010 - 20:46
Actually i wont be using be using CME. I will only be terminating the voice traffic from WAN link and sending it to PSTN. Can i still use third party billing software for that purpose.
