vpn monitoring
Jan 30th, 2010
Gurus,
Do we have a way to monitor site to site or SSL VPN ( anyconnect) for tracking users logins, things conducted by user during the session & any further checks that may need to be done.
Appreciate any help on this.
Thanks!
pudawat Sun, 01/31/2010 - 09:05
Hi Thomas,
You need to enable SYSLOG following messages on the ASA:
722007
Error Message %ASA-3-722007: Group group User user-name IP IP_address SVC Message:
type-num/ERROR: message
Explanation This is a message from the SSL VPN client (SVC) .
type-num— A number from 0 to 31 indicating a message type. Message types are as follows:
0—Normal.
16—Logout.
17—Closed due to error.
18—Closed due to rekey.
1-15, 19-31—Reserved and unused.
message—A text message from the SVC.
722037
Error Message %ASA-5-722037: Group group User user-name IP IP_address SVC closing
connection: reason.
Explanation An SSL VPN client (SVC) connection was terminated for the given reason.
reason—The reason the SVC connection was terminated.
113019
Error Message %PIX|ASA-4-113019: Group = group, Username = user, IP = peer_address,
Session disconnected. Session Type: type, Duration: duration, Bytes xmt:
count, Bytes rcv: count, Reason: reason
Explanation This is an information message.
group—group name
user—username
peer_address—peer address
type—session type (for example, IPSec/UDP)
duration—connect duration
count—number of bytes
reason—disconnect reason
Recommended Action None.
Pradhuman
