Secondary Internet Link Installation
Jan 31st, 2010
We are using 2 internet links on ASA--5550. Right now default route is towards primary ISP and only Static routes are in use towards second link.
Is it possible to shift Remote VPN users traffic on second link with current setup.
Prince
Ganesh Hariharan Sun, 01/31/2010 - 23:48
Prince
Hi Prince,
As per the configuration of remote to site von configuration outside ip address needs to be the front end phase for initaition of vpn tunnel in your case the interface will be changed to secondary interface which is facing towards the ISP2 so you need to change the configuration in firewall and need to select the outside interface of ISP2 facing interface.
Check out the below link hope this helps
http://www.cisco.com/en/US/docs/security/asa/asa72/getting_started/asa5550/quick/guide/remvpn_n.html#wp1046899
Ganesh.H
