Is it possible configure the ASA to user SSL VPN to authenticate in the radius through the L2L VPN?
Jan 31st, 2010
Hi experts,
Attached to this mensage I put a image .jpg with my topology. Is it possible configure the ASA to user SSL VPN to authenticate in the radius through the L2L VPN?
In ASA console a I do not can ping the radius IP address 10.0.79.15. There are some thing that I can to do for this design to work?
Rodrigo Alves
yamramos.tueme Thu, 02/04/2010 - 13:11
Hola Rodrigo!
I am not sure the way your L2L tunnel is configured, but most probably you will need to add the outside ip address of the ASA to the VPN intresting traffic of this tunnel (crypto map ACL).  When you configure your AAA server, you specify the interface traffic should go through in this case it will be the outside interface and that will make packets going to the authentication server to be sourced with the external ip address.
On both ends of the tunnel just add the traffic crypto map ACLs that allows ASA outside ip address go to the Authentication Server.
Cheers!
- Yamil
