cisco 10 G Switch with high buffer
prafulla_nigam
Hi friends....
I am looking for switch having 1 10G port and 8 to 10 1G ports.
Please suggest me any model for my requirement. I am looking for switch with high buffer inbuilt.
Thanks all..
Ganesh Hariharan
Hi friends....
Thanks all..
Cisco 3560 E series and 3750E series support 10 G port and 1 G ports ,check out the belwo link on both the models hope that helps
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7078/product_data_sheet0900aecd805bac22.html
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7077/product_data_sheet0900aecd805bbe67.html
If helpful do rate the valauble post
Ganesh.H
thanks Ganesh....
I gone through the models suggested by you,.. so far i understand that these are the Aggregation Switch... Let me explain my requirement in bit details..
I am having senario in which I will be having 1 input link with speed of 10Gig, and this 10Gig traffic i need to distribute over 10nos 1Gig ports on same switch...
I am checking for some more information for this that if this switch can meet my requirement.
Please suggest with your openions ....
thanks.. again....
thanks Ganesh....
thanks.. again....
Hi ,
For your query and senario that i input with 10 Gig and traffic will shared among other 1 G ports in the same switch will be relates to the backplane capcity of the switch how fast it do switching.Basic defination of backplane in cisco switches may define as a switching fabric is the combination of hardware and software that moves data coming in to a network node out by the correct port (door) to the next node in the network. A switching fabric includes the switching units in a node, the integrated circuits that they contain, and the programming that allows switching paths to be controlled.
and if you see the backplane capcity as per the link in cisco 3750 E is 68-Gbps, wire rate backplane.
check out the below link on backplane for cisco 3750E
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps7077/prod_bulletin0900aecd805bbe54.html
Hope that help !!
If helpful do rate
Ganesh.H
