http service unavailable on this node
Feb 1st, 2010
Hi All,
Just a question for anyone who has seen this at all.
(Might be staring me in the eyes!)
I http to Fabric Interconnect (A) and java works fine. Type in the uname and password and log in to UCSM
I http to FI(B) and java work also fine prompting me for a uname and password. Once done I get an error message saying
"Http service unabailable on this node"
So then I log into the cluster address, log in to UCSM and check out the admin settings for http. They are bot enabled.
I then putty into each FI and do a status of http and https for both FI's. THey show as enabled.
If http is enabled on both FI's why is it that I can log into UCSM on one and not the other?
gd
Robert Burns Mon, 02/01/2010 - 07:31
UCSM will only allow you to log into the Virtual IP when setup in a cluster configuraiton.  Though you can SSH to either FI directly, you should only ever access UCSM from the Cluster IP.
Robert
Grace Zhu Sat, 10/01/2016 - 13:37
UCSM only allow login through GUI with cluster IP or the PRIMAY FI IP
