acs appliance with flapping ethernet interface
Feb 1st, 2010
we have an acs appliance with software 4.0. Since a couple of weeks the ethernet interface of the appliance starts to flap every minute. Neither changing the switchport nor the cable or the switch was not succesful.
Does anybody know a bug ?
Best regards
Torsten Waibel
Ganesh Hariharan Mon, 02/01/2010 - 23:22
Best regards
Torsten Waibel
Hi Torsten,
Just try to configure a command via console toggle nic in ACS appliance and then check it happen or not.
If helpful do rate
Ganesh.H
t.waibel Wed, 02/03/2010 - 04:18
Hi Ganesh,
sorry the command is not known by the windows acs appliance.
acs2>  toggle nic
toggle nic: command not found.
Our hardware suppliers doesn't found any bug together with cisco.
Finally we will change the hardware.
Best regards
Torsten
