Cisco ACS 5.1 Evaluation Version Very Slow
Feb 1st, 2010
I have installed the Cisco ACS 5.1 eval copy on one of our server (HP DL 320 with  2GB RAM , 146 GB, Intel Pentium 3GHz).The problem I am facing is that the while trying to open any thing (User & Identity Stores, Network Rsources) etc , it takes a lot of time to open. Even when I try to login it takes a lot of time (10 to 20 mins) on avg
How can I come to know that what processes is taking so much time
I have checked the network connectivity is not an issue
Need help in troubleshooting the long response times
Overall Rating: 3 (1 ratings)
Erick Delgado Fri, 02/05/2010 - 08:46
Is the ACS the only server install on the vmware box? I had seen this issue before it is a hardware limitation. If you have more than one server on the WMWARE please shutdown the rest of the servers and try again.
yusuf.ujjainwala Fri, 02/05/2010 - 21:31
I found out what the issue was , the ACS server requires minimum 512 MB RAM and our VM was assigned only 384 MB , one I upgraded the RAM to 1GB , the problem got resolved
