IDSM-2 re-image issue
Feb 1st, 2010
Hi Netpros,
I am getting this error when I trying to re-image the IDSM-2 in maintenance partition. Actually I dont know the password for the administrator account and re-image was only option according to documentation. This is the step i am following:
[email protected]#upgrade ftp:[email protected]//WS-SVC-IDSM2-K9-sys-1.1-a-6.0-2-E1.bin.gz --install
Downloading the image. This may take several minutes...
Password for [email protected]:
ftp:[email protected].198//WS-SVC-IDSM2-K9-sys-1.1-a-6.0-2-E1.bin.gz (25662K)
/tmp/upgrade.gz           [########################]   25662K | 8838.99K/s
26278451 bytes transferred in 2.90 sec (8838.70k/sec)
ERROR:  /tmp/upgrade.gz: not in gzip format
Am i missing anything?
-- FAIZ
rhermes Mon, 02/01/2010 - 08:35
  • Gold, 750 points or more
It looks like your commands and the image file are correct.
Did you boot the IDSM into the maintenance partition before you started?
from the router:
hw-module module (module number) reset cf:1
after upgrading reboot the IDSM into the application partition:
from the router:
hw-module module (module number) reset hdd:1
Mohammed Faiz M... Mon, 02/01/2010 - 22:25
Yes I did exactly what u have mentioned, but the ERROR message
in the end is strange isnt it.
Please let me know if anyone has come across similar kind of problem.
Any feedback appreciated.
--Faiz
rhermes Tue, 02/02/2010 - 10:34
It looks like you are following the instructions for installing an IDSM system image in this guide:
http://www.cisco.com/en/US/docs/security/ips/6.0/configuration/guide/cli/cliImage.html#wp1031992
If you have performed each step as described and are still getting this error message, you might want to open a TAC case on your IDSM.
If your IDSM is defective, they can RMA it (assuming you have a maintainence contract).
- Bob
