License Install in Nexus 7000
Answered Question
Feb 1st, 2010
   I wanna install a license file (.lic) in a Nexus 7000
    I'm reading the Nexus 7000 License Configuration Guide and in that document I read that you need to access the console (Active
    Supervisor Module) before you use the install license command..
    My question is, can I execute the same command (install license) via SSH or Telnet ??
    Thanks in Advanced
      My Best Regards,
Correct Answer by Lucien Avramov about 7 years 3 weeks ago
Yes you can via telnet or SSH install license. As long as the license file is already uploaded to your flash card on your router.
Correct Answer by sachinraja about 7 years 3 weeks ago
Hi lomonaco
I think you should be, but never tried before .. This document says you need to install it thro console :
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_2/nx-os/licensing/guide/Cisco_Nexus_7000_Series_NX-OS_Licensing_Guide__Release_4.2_chapter1.html
but with other devices like routers, we have the "license install" command which we do it remote.. so, i think it must be the same here..
Does it give you an error when you configure this remote , thro telnet or SSH ?
Raj
Overall Rating: 5 (1 ratings)
Correct Answer
sachinraja Mon, 02/01/2010 - 07:25
Hi lomonaco
Raj
Correct Answer
Lucien Avramov Mon, 02/01/2010 - 13:39
lomonaco Fri, 03/05/2010 - 07:01
Thanks Raj and Lucien for you help...
Works as expected
  My Best Regards,
   Andre Lomonaco
