Server Networking
Cisco UCS X-Series Energy Efficiency Offer
Hello All, Question in Nexus 9.x    We have an EoL notice for version 9.3x.  There's no replacement available at this time.   Can we assume that a version 9.4 version will be released?   I don't see any EoL for 9.x at this time.  The customer doesn't...
HiI'm working with a customer that has a Dual DC setup with 2 x Nexus 5600's in each DC in a vPC setup. These switches connects the two DCs together with 4 x 10G using FabricPath. The customer will leave one of the DCs and during the migration the ne...
I have Deployed a ASAV in Azure infrastructure I have logged into the ASA through the management interface with the public interface thats was created when it was deployed . I want to use gi0/0 as the outside interface. I configured the NiC-1 with a ...
Hi,I've developed a management pack to monitor devices in Cisco DNA center via SCOM. The management pack uses the API to collect data and to alert when a device that is in Cisco DNA Center is unreachable. This helps to make SCOM the single pane of gl...
bpinoy by Level 1
  • 332 Views
  • 1 replies
I have a pair of Nexus 5548s in the lab. I'm trying to build a VPC to a C220M3 using a P81E adapter. I cannot get the int port-channel 30/vpc 30 to come up. Any ideas?B5548# show vpcLegend:                (*) - local vPC is down, forwarding via vPC p...
jogentry by Level 1
  • 6257 Views
  • 4 replies
Dear all, I created to RAID-1 as virtual hard-drive in order to install Vmware and  later cisco NCS software at ciscı C220 M3. I followed the  all the procudure then l was succesfull to istallation of softwares. I just a small problem  that when ı re...
