<Protect_IVR_FactoryReset> does not work on SPA525G
Feb 1st, 2010
Does not protect LCD display for factory reset
Firmware is 525G , works on 504 . 502, 942,962
<Protect_IVR_FactoryReset ua="na">Yes</Protect_IVR_FactoryReset>
Steven Smith Mon, 02/01/2010 - 09:33
  • Gold, 750 points or more
What firmware are you running on the 525?
CSCtd35385 spa525: factory reset is allowed with admin pw and protect IVRfactoryres
This should be fixed in 7.4.3.
FlyingDoctor_2 Mon, 02/01/2010 - 09:48
Sorry Thought I had put firmware version
is 7.4.3
problem is that admin password not set via
set password on Web and factory reset prompts for password as should
FYI  - some LDAP config fields are also broken on the 525 - could be related
Steven Smith Mon, 02/01/2010 - 10:01
Admin password is required for this Protect_IVR_FactoryReset to work.
Which LDAP fields are you saying do not work?
FlyingDoctor_2 Mon, 02/01/2010 - 10:28
I know the admin password is required
What I am saying is that is not being set by the xml
Steven Smith Mon, 02/01/2010 - 13:19
Can you send me the XML you are using?
FlyingDoctor_2 Tue, 02/02/2010 - 00:07
Our  XML is generated dynamically so there is no file, I would not post our config on a public forum anyway
This is the bit you need - I have changed the passowrd
This works on 941,942 962, 504 and 502
......xxxxxxxxxYes........
FlyingDoctor_2 Tue, 02/02/2010 - 06:48
it is another 525 gratuitous field  name change  -> is now (only on 525)   Admin_Password
nseto Tue, 02/02/2010 - 09:12
  • Silver, 250 points or more
What is meant by xml generated dynamically?  The xml is usually made by using the spc tool.
FlyingDoctor_2 Tue, 02/02/2010 - 15:27
we have many 1000's  of phones - we generate the xml on the fly when requested by the device
The issue here is not how the XML is generated , but inconsistences in the field names between the 525G and other devices
nseto Wed, 02/03/2010 - 10:28
Please go into more details regarding inconsistent info between the products, I'll be able to write a bug report based on this info.
FlyingDoctor_2 Mon, 02/08/2010 - 09:05
The list is growing
  • Programmable_Softkey_Enable  only on 525
  • Admin_Password different
  • Several LDAP Directory fields different
nseto Mon, 02/08/2010 - 10:36
Ok, thanks.  I'll write up a bug regarding these field name issues.
