EoMPLSoGRE
Feb 1st, 2010
I'm moving this https://supportforums.cisco.com/message/2016937#2016937 discussion here because I feel I will get a quicker response.
In a nutshell the setup is as below:
ASR1004=={ GRE }==C7206
I need to run layer 2 services between the 2 without mpls support from the service provider. Unfortunatelly there is no specific detail on getting EoMPLSoGRE up and running.
I have the GRE tunnel working and I have mpls forced to my loopbacks and the xconect configured on the 2 router interfaces.
however the mpls forwarding table on the 7206 shows the outgoing interface is 'none' and I cannot pass any traffic across.
7206>sh mpls forwarding-table
Local  Outgoing    Prefix            Bytes tag  Outgoing   Next Hop
tag    tag or VC   or Tunnel Id      switched   interface
200    Untagged    l2ckt(303)       0          none       point2point
On the ASR it looks fine:
asr>sh mpls forwarding-table labels 201
Local  Outgoing      Prefix            Bytes Label   Outgoing   Next Hop
Label  Label or VC   or Tunnel Id      Switched      interface
201    No Label      l2ckt(303)       0             Gi0/0/7    point2point
Giuseppe Larosa Mon, 02/01/2010 - 13:05
  • Hall of Fame,
    Founding Member
have a look at this nice document
http://www.cisco.com/en/US/prod/collateral/routers/ps9343/Deploying_and_Configuring_MPLS_Virtual_Private_Networks_In_IP_Tunnel_Environments.pdf
I'm afraid it is not supported on C7200.
What IOS image is running on C7200 and what NPE model is present?
Hope to help
Giuseppe
madhaquer Mon, 02/01/2010 - 21:41
Thanks for the response.
I'm running Version 12.4(11)T4 with a NPE-G1 processor.
I will try out the example on the case study before i give up.
moitani Tue, 02/14/2012 - 03:41
Hey,
I know this thread has been here since 2 years back, but I currently need to do Data Center Interconnect (DCI) and need somebody to tell me that this solution (EoMPLSoGRE) does actually work.
On what platforms?
What IOS?
Please advise.
