Hide users on CUCM 6.1.3
Feb 1st, 2010
Hi all,
I need to hide users from being seen from corporate directory option on IP phones but in the same time users like "JTAPI" user should functions well without any problems.
I have CUCM 6.1.3
Any ideas,
Ahmed Kamal
rcrumm_2 Thu, 02/04/2010 - 11:45
You can create another container in AD and move users you want to hide from their. You also need to make sure the new container is not in the LDAP user search base.
rcrumm_2 Fri, 02/05/2010 - 08:54
You need to check the LDAP Directory. In CUCM check system/LDAP/LDAP Directory. It is probably pointing to tiyr Users container.
If so, create a container in AD and call it say, Hidden users, and move your users over there.
Then do a LDAP sync on the LDAP directory and they should be hidden
