Routed Ports
Feb 1st, 2010
Dear Experts,
I'm a newbie to what's called Layer-3 Switching and Routed Ports
I Have 2 Layer-3 Switches (Cisco 3560 and 2960), I have my Headquaters LAN Network (192.168.0.0/24) and my Branch Network (192.168.1.0/24)
I want to use the WAN link to connect them to each other using Routed Ports (because actually I have no routers)
How can I configure that using Routed Ports on both switches - let's assume that I will use 192.168.100.1 and 192.168.100.2 for the routing interfaces
Thank in advance for your kind co-op
paolo bevilacqua Mon, 02/01/2010 - 10:18
  • Hall of Fame,
    Founding Member
First of all the 2960 is not a L3 switch.
On the 3560:
ip routing
interface x/y
switchport mode access
switchport access vlan 10
interface vlan 10
ip address a.a.a.a m.m.m.m
That's it.
Jon Marshall Mon, 02/01/2010 - 10:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
m.metwally wrote:
Dear Experts,
As Paolo says the 2960 is not a L3 switch so on the 2960 use Paolo's config ie.
int vlan 10
ip address 192.168.100.1
int gi0/1
However the 3560 is a L3 switch so on that one
int gi0/1
no switchport
ip address 192.168.100.2
And enable "ip routing" on the 3560.
Jon
paolo bevilacqua Mon, 02/01/2010 - 10:36
  • Hall of Fame,
    Founding Member
Either "no switchport" and address on interface, or "switchport" and address on VLAN, achieve the same result.
Jon Marshall Mon, 02/01/2010 - 10:39
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Not really. The poster asked about routed ports. Routed ports cannot be switchports hence the "no switchport". Switchports work at L2 whereas routed ports do not.
They do achieve the same result but in a different way and it's an important difference. Switchport + vlan interface still run STP across the link, routed ports do not.
Jon
milan.kulik Tue, 02/02/2010 - 05:27
  • Red, 2250 points or more
one basic question:
What type of WAN link are you using?
Is it terminated by FastEthernet ports on both sites?
HTH,
Milan
m.metwally Tue, 02/02/2010 - 13:21
dears,
i have connected the two network successfully through two 3560 switches but, one of these 3560 switches (headquaters) is connected to three 2960 switches through cascaded trunks, so the other 356 switch (branch) can see only the devices that connected to the headquarters switch and cannot see any of other computers connected to any 2960 switches although in headquarters -internally- all devices can see each others
3 vlans are configured on the headqurters switches and trunks are configured simple as "switchport mode trunk"
plz advise
paolo bevilacqua Wed, 02/03/2010 - 03:54
  • Hall of Fame,
    Founding Member
Wouldn't be better if you was to engage a Cisco dealer or reputable professional that can setup your network optimally in less than one hour ?
