SLM 2005, can´t reach the web-based utility 192.168.1.254
Feb 1st, 2010
Hello, first to tell you, that my english is not the best, i´m from germany, so sorry for that.
I can´t get on the web based utility to install the Vlan  or other thigs on my Switch SLM 2005
I use a D link Dir  655 Router, also use DHCP, but my Router don´t find the switch.
I try to get over Internet Explorer on the web face from the SLM, over 192.168.1254. but i can´t reach it.
Also i made a restart on the sitch, just use a laptop  but nothing to get on the web face.
Any help from you , please ???
Best regards
Andre
Kevin Dorrell Wed, 02/17/2010 - 14:45
  • Green, 3000 points or more
The laptop you are using to try to get into the switch ... is its IP address also in the 198.168.1.x network?
Kevin Dorrell
Luxembourg
