02-01-2010 10:48 AM - edited 03-06-2019 09:32 AM
Hi guys.
We are using qos per-port per-vlan in all user ports of our Cat4510+sup6e boxes. By this way in each port we have attached two policy-maps for data vlan and voice vlan.
Well, we are trying to obtain per-port qos statistics using "show policy-map interface gigabitethernet x/y" command, but we obtain the same statistics in all ports (the same amount of matches for traffic classes in all ports). We thing chasis is showing us agregate o global statistics por each vlan.
Is there anyway to obtain real per-port, per-vlan statistics? is this a bug in 12.2(53)SG IOS version?
Thx.
02-02-2010 11:43 AM
Please post the relevant portion from the config along with the show policy-map interface output.
02-02-2010 11:49 PM
Hi Edison, thanks for your response.
Take a look to this port config port. It is the same config for all ports. You can see we have attached a different policy-map for data vlan and voice vlan.
interface GigabitEthernet1/3
description Usuario
switchport access vlan 253
switchport mode access
switchport voice vlan 263
no logging event link-status
load-interval 60
no snmp trap link-status
spanning-tree portfast
spanning-tree bpduguard enable
vlan-range 253
service-policy input pm_accesodat
vlan-range 263
service-policy input pm_accesovoz
If you try "show policy-map interface GigabitEthernet x/y" you will see the same output for all ports (you can see it in attached files, we are thinking show policy-map command is showing aggregated statistics for both vlans), and we want to know if it´s possible to obtain this command output specifically for one port.
02-03-2010 08:15 AM
You are correct.
QoS is being applied to the Vlan and not the switchport so I recommend changing your configuration as followed:
Interface GigabitEthernet1/3
description Usuario
load-interval 60
service-policy input Voice_Data
class-map cm_acceso_voz
match access-group name acl_acceso_voz
class-map cm_acceso_video
match access-group name acl_acceso_video
class-map cm_acceso_senyalizacion
match access-group name acl_acceso_senyalizacion
class-map cm_acceso_protocolos_control
match access-group name acl_acceso_protocolos_control
class-map cm_acceso_aplicaciones_criticas
match access-group name acl_acceso_aplicaciones_criticas
class-map cm_trusted_voz
match ip dscp ef
class-map cm_trusted_senyalizacion
match ip dscp cs3
policy-map Voice_Data
class cm_acceso_voz
police cir 192000 bps bc 6000 bytes
class cm_acceso_video
Set ip dscp af41
class cm_acceso_senyalizacion
Set ip dscp cs3
police cir 1000000 bps, bc 31250 bytes
class cm_acceso_protocolos_control
Set ip dscp cs6
class cm_acceso_aplicaciones_criticas
Set ip dscp af21
class cm_trusted_voz
police cir 192000 bps, bc 6000 bytes
class cm_trusted_senyalizacion
class class-default
set ip dscp default
03-30-2010 07:06 PM
I have a couple dozen 4500's with Sup-6E's. "show policy-map interface" counters are broken in the current code train your using. Its still not fixed in 12.2(53)SG train. It does not matter whether you use per-port or per port per vlan. I have both QOS types configured and TAC confirmed the code problem with those counters. Its doing exactly what you suspect showing aggregate counters for all ports. Its ashame this is not fixed yet.
