Cisco 857w ADSL configuration
Feb 1st, 2010
Help me in configuring of cisco adsl 857w for DHCP.
Can anyone send me the sample for this configuration.
Thanks!
Giuseppe Larosa Mon, 02/01/2010 - 12:52
Hello Er,
do you want the router to behave as a DHCP server or to be a DHCP client on one of its own interfaces?
a) client
  int fas0/0
ip address dhcp
b) server router acting as DHCP server for one or more subnets that are directly connected
see this example:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tabella normale"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
ip dhcp excluded-address 10.110.224.129 10.110.224.132
ip dhcp excluded-address 10.110.224.145
ip dhcp pool DATA
   network 10.110.224.128 255.255.255.240
   default-router 10.110.224.129
   dns-server 10.98.112.32 10.55.0.32
   netbios-name-server 10.52.64.37 10.24.128.151
   lease 0 1
ip dhcp pool VOICE
   network 10.110.224.144 255.255.255.248
   default-router 10.110.224.145
   option 150 ip 10.98.67.5 10.55.61.4
   lease 0 1
first pool is for PCs, second pool is for Cisco IP phones option 150 specifies TFTP servers
interface FastEthernet0/0
no ip address
no ip route-cache cef
no ip route-cache
duplex auto
speed auto
interface FastEthernet0/0.10
description VLAN DATA
encapsulation dot1Q 10
ip address 10.110.224.129 255.255.255.240
no ip redirects
no ip route-cache
no ip mroute-cache
interface FastEthernet0/0.20
description VLAN VOICE
encapsulation dot1Q 20
ip address 10.110.224.145 255.255.255.248
no ip redirects
Hope to help
Giuseppe
