3750 G - Stack Question
Feb 1st, 2010
Hello All:
I had 2 3750's stacked and had to split them. I disconnected them and issued the np provision command for #2. All is well except the switch ports on the 2nd switch are still labeled as 2/0/0x instead of 1/0/1x  etc. How can I revert that switch back to prestack time.?
DJ
sachinraja Mon, 02/01/2010 - 11:53
  • Red, 2250 points or more
Hi DJ
Can you give "show switch" on the second switch  and see the stack number on it ?
try the command " switch member-number renumber new-member-no"
specify the current stack number (which i presume is 2), and then the new stack number (which is 1 ?)
then do a reset to the stack member (reload) and see if it comes back..
verify by giving a show switch again..
Hope this helps.. all the best..
Raj
