IDE tool to do development that will be used with CVP
Answered Question
Feb 1st, 2010
Hi All;
I got to know that there is a development tool that can be used for doing java classes files to be used in CVP, it is an IDE tool but for Cisco, can anyone advise me from where I can get it and information about it?
Your kindly help is high appreciated.
Bilal
Correct Answer by manoj_anantha about 7 years 3 months ago
As i told earlier, you could use CVP studio to build java class files. If you still wanted to use a different IDE then you could use:
Eclipse:
http://www.eclipse.org/downloads/
Netbeans:
http://netbeans.org/
These IDE are free, but will not have CVP VXML application development plugins.
-Manoj
Overall Rating: 5 (2 ratings)
manoj_anantha Mon, 02/01/2010 - 12:36
You can use the CVP studio to build the Java class files as well. CVP studio is basically an Eclipse IDE with Audium licensed package to build CVP VXML application. Create a JAVA application and you could write JAVA class files.
If you do not have a CVP studio then you need to purchase it from Cisco. The license is tied to the System ID.You can also use the 60 days trail on the CVP studio.
-Manoj
bilalghayad Tue, 02/02/2010 - 00:19
Appreciate the greate help and kindly advise.
Where I can get the NetBeansIDE? Is it licensed or free?
Bilal
Chad Stachowicz Tue, 02/02/2010 - 10:41
  • Silver, 250 points or more
well its important to note that regardless of developing a java class, you still must make at least a small VXML application to launch the class, which you will need CVP studio for anyways.  Get yourself a copy through your company if your planning on doing any serious development work for CVP.
Chad
